How Are Concrete Sectional Garages Built?
Concrete sectional garages are extremely sturdy and built with much more structure than most of the other materials such as wood. If you are interested in learning how concrete sectional garages are built, here are a few steps that can help you better understand.
Planning and Staking
One of the biggest steps when it comes to a concrete sectional garage is the planning and staking part. This way, you know where to build and have a frame to work off. Typically, measurements will be done first, then shovels are used to dig out around the perimeter about 6 inches deep. Then form boards are set into the perimeter to make sure that the place is help and staked out.
Securing the Boards
Once you put the form boards into the actual dug holes, you have to make sure that they are put together and secure as they are the base of the entire structure. To do this, nail together the corners of the form boards where they meet. This step can be done with a hammer and nails or using a drill. When doing this, you may want to use double-headed nails. This is because you will later need to take the form boards out and they can easily be removed with the double head.
Install the Rebar
This can be a tricky part of the process. You will need to dig out the footings around the perimeter and then put 1/2-inch rebar along the footings. Typically you can find rebar at the hardware store near you or if you are looking for a great price, you can check online to see if they have a discount and delivery. It is important to make sure that you are leaving a space between the earth and the rebar as you install. Then you will need to attach the rebar rods so that they are extending up into the air. This is to allow the concrete to be laid over them.
Install Vapor
Sand and a vapor barrier need to be added in order to keep moisture out and keep the form. Make sure that the sand is raked so that it is flat and leveled out.
Pour the Concrete
Once you have your base set out you can pour the concrete. You have to mix it in a wheelbarrow according to the instructions and make sure that the consistency is similar to that of cake batter. It should be thick, but not too thick that you can't pour it with ease. Continue to pour the concrete over the garage base and floor. Use a trowel to level everything out and be sure to work slowly from one end to the other, being careful not to miss any spots. Once you have finished pouring and the concrete has begun to set, you will want to make a few slashes in different spots. This allows the concrete to withstand different temperatures and keeps it from cracking.
