How can I build a portable carport? How can I build a portable carport?
Portable carport kits are easy to assemble. Begin by unpacking the pieces and familiarizing yourself with the layout. Starting with the side frame poles, insert the smaller poles into their corresponding pieces and continue the process with the roof poles. Then attach the side poles into the roof connectors with the assembly lying on its side. Raise the assembled frame into an upright position and place it in the desired location and position. Unroll the cover and drape it across the frame evenly. Secure the cover at the corners and then secure the side flaps. The method of securing depends on the manufacturer. Use stakes and ties to anchor the structure to the ground.
