How can I check if my kitchen sink is clogged on both sides? How can I check if my kitchen sink is clogged on both sides?
A kitchen sink can be clogged by many things. Grease is a common cause of clogged drains. Food or debris can also wash into the drain, causing it to clog. Hair and even dirt can also lead to a clog. To check for a clog, remove all dishes and drain plugs from the sink and run water into both sides. If the water drains slowly, or not at all, then you will know that a clog is present in one or both sides. These clogs can be removed with the use of chemical solutions or with a plumber’s snake. Calling in a professional plumber for help may be needed if you are unable to dislodge the clog on your own.
