Quick Advice on Repairing Basement Window Wells
Your must repair damaged basement window wells to prevent water from leaking into your basement. The first step is to identify any cracks in the wall around the window. Use a hammer and chisel to make the crack large enough to fill with cement. Use a trowel to apply cement filler to the cracks. Next, install a well duct system by drilling through the wall under the sill. Fit a metal pipe through the hole snugly. It should extend from the exterior into the basement’s interior. Place a screen over the pipe on the exterior. Attach the well duct over the pipe on the interior and secure it to the wall. Water will enter the new structure, then flow out of the house.
