How Can I Keep My Backyard Fire Pit from Leaving Marks on the Grass? How Can I Keep My Backyard Fire Pit from Leaving Marks on the Grass?
A backyard fire pit will leave marks on your grass due to the heat and it mat keep the grass below it from getting sunlight. To combat this issue, you will need to purchase a special pad that is made to protect the grass from the heat. You place the pad under the pit prior to lighting the fire. On the other hand, you will need to remove the pad the next day or the pad itself will damage the grass. You will have to move the fire pit each time you use it to completely prevent and do away with the marks in your grass.
