How can I remove drywall without damaging anything? How can I remove drywall without damaging anything?
If you plan to remove drywall, the areas surrounding the drywall that you wish to remove are at risk of being damaged, if you do not practice care. For this particular task, use a drywall saw or a utility knife to remove the drywall with ease. Cut a small square hole through the drywall, to see what is inside. Gently, use the saw to cut down, up and at the side. Cut another square, and another, until you have covered the entire drywall area you wish to remove. Although this process is slow, it is the surest way to remove drywall, to avoid damaging anything important.
