How can I use my homemade scaffolding? How can I use my homemade scaffolding?
Scaffolding is used by many workers and do-it-yourself enthusiasts when using a ladder isn't acceptable. Scaffolding gives you freedom of movement in a work area and more stability when you are several feet in the air than a ladder will. Many people build their own scaffolding rather than rent or lease it. This is usually the situation if a scaffold needs to be used for a long period of time and the cost of renting would be prohibitive. Homemade scaffolding is used the way rented or purchased scaffolding is used once you have determined that it is safe. The added benefit is you can take it apart and store it to use again on other projects.
