How do I clean my bathtub drain stopper? How do I clean my bathtub drain stopper?
The bathtub drain stopper can get a dirty, as a result of hair, soap scum, dead skin cells and other debris going down the drain. When cleaning your bathtub drain stopper, it is easier to do if the bath is holding no water. Simply remove the plug. If it is a lift and turn drain stopper, then you will need a screwdriver to remove a screw and detach the stopper. Now you will be able to see the debris, remove it by poking in a straightened out wire coat hanger and pulling up the debris out. Once clear, pour some bleach down the drain, and reattach the bathtub drain stopper.
