How do I get glitter wall paint off my walls?
  • 1-3 hours
  • $210-250
Sandpaper
Electric sander
Respirator mask
Safety glasses
Vacuum cleaner
Sandpaper
Electric sander
Respirator mask
Safety glasses
Vacuum cleaner
Glitter wall paint is actually paint that has had tiny bits of granite added to it for a glitter look. It is popular in children's rooms and where an ethereal effect is desired. If you wish to remove it you have a bit of work in store.
Glitter wall paint can be removed by sanding the walls using an electric sander. This is a dusty, messy job that will take a great deal of time.
  • Start by getting a respirator mask, safety glasses and your sanding tools (get medium grade sandpaper).
  • Seal off all the adjacent rooms and make sure any children or pets are clear of the area.
  • Remove all furniture, rugs and curtains from the room. If desired, put down plastic sheeting.
  • Once you're finished sanding, use a vacuum cleaner to remove the paint and sawdust.
