How do I remove paint from vinyl window frames?
If you get paint onto your vinyl window frames, follow the simple steps below to effectively remove it.
Step 1 - Wipe Away the Paint
Wash the paint off using a soft rag dipped in warm water with a little detergent added. This will remove most latex paints.
Step 2 - Scrape the Residue
Gently scrape the paint off using a smooth plastic tool such as a putty knife. Don't scratch the vinyl by pressing too hard.
Step 3 - Apply Paint Remover
Use a paint remover approved for use on vinyl. Apply the remover to the paint only and rinse the paint residue off with a wet rag. Then rinse the frame using a a soft brush and clear water and dry.
