How do I use a sliding miter saw? How do I use a sliding miter saw?
A sliding miter saw is fairly easy to use, as long as you follow a few basic guidelines. It is also crucial to exercise caution by wearing safety gloves and goggles. A fundamental rule is to make sure not to place your hands anywhere near the blade. Mark the area where you have to cut. Then, lay the wood on the bed of the saw and move the blade to the area where you intend to cut. It is crucial to match the angle required by tilting the blade accordingly. In most cases, you attain this adjustment by rotating a knob. Once the blade is in the right position, press the power button and carefully lower the blade onto the wood so as to make the cut.
