How Much Weatherstrip Adhesive Do I Need to Apply? How Much Weatherstrip Adhesive Do I Need to Apply?
When you are trying to apply weatherstrip adhesive, you need to make sure that you do not use too much. Otherwise, it might start to come out around the edges of the strip. You should apply only a thin bead of adhesive to the center of the area where you are going to install the weatherstrip. Then you can press the weatherstrip down into the adhesive, and the substance will then spread out and cover the entire backing of the weatherstrip, efficiently holding it in place.
