How often should pool deck pavers be resealed?
Pool deck pavers should be resealed every 1 to 3 years, depending on the quality of the sealer used. Lower quality sealers will wear off more quickly, prompting you re-apply it on your pavers sooner. The higher quality pavers, however, will last about 3 times as long, making so you need to apply them only once every 3 years. The quality of the sealer definitely matters when it comes to maintenance and re-application, so it is better to get the best one that you can afford because it will save you more money in the long run, not to mention the effort that you will put more often in re-sealing the pool deck pavers.
