How should I clean my driveway culvert pipes?
Cleaning driveway culvert pipes is a difficult job as these pipes can be pretty long and are buried underground. Choosing the right material is important as this will reduce the frequency of the cleaning project. Dirt and debris clings to the inside of metal pipes more than to the inside of plastic pipes, for example. To clean the inside of a culvert pipe, use a pressure washer to flush out any accumulated dirt. If you do not have access to a pressure washer, then weld a long pipe to the handle of a shovel to make a contraption long enough to reach the length of the driveway culvert pipe.
