How should I ventilate a smell pellet stove? How should I ventilate a smell pellet stove?
A small pellet stove should always be ventilated, as the fumes caused by burning the wood can be dangerous if inhaled over a prolonged period of time. If you have a chimney, then the stove can be ventilated up the chimney. This is a cheap method of venting, as no building work is required. If you do not have a chimney, then the pellet stove can be vented through a man made vent, directing the fumes outside your home. The best vent for this is a mechanical vent, as it not only pushes the dirty air outside, it circulates clean air back into the pellet stove to keep it burning strong.
