How Thick Should Concrete Pool Decking Be? How Thick Should Concrete Pool Decking Be?
Installing concrete pool decking can be a good way to create a deck that is both functional and durable. If you are doing this job yourself, you must first determine how thick you need to make the concrete pool decking. As a general rule, you should not make a concrete deck less than 4 inches thick. This depth will keep the deck strong enough to withstand general wear and tear. You could choose to make the deck 6 inches thick for good results.
