How to Build a Hidden Door Bookcase How to Build a Hidden Door Bookcase
Bolts
Drawing kit scale, pencil, paper
Wood
Steel
Hinges
Door stop
Brass flange bearing
It is a very common and an effective idea to use a hidden door bookcase to disguise an entrance into a secret place of a house. Making such a bookcase may appear quite difficult to most of the people, however it is not the case. You can do it yourself without the help of any professional. All you need is some skills to work with wood. It would require you around 3 hours to complete this work, so you can plan your schedule accordingly. Follow the steps that are described in the article below to make a bookcase that meets your requirements.
Step 1 – Calculate the Dimension
Measure the length, breadth and height of the hidden door bookcase you want to build. While calculating the dimensions of the bookcase, keep in mind various things such as the pivot point, clearing the walls and keeping some gaps with the neighboring shelves.
Step 2 – Important Variable to Consider
Include the length and hence the swinging radius of the door (when it is opened) while doing your calculations.
Step 3 – Make the Steel Frame
Make a steel frame to support the wooden shelves so that the door can swing easily without breaking down.
Step 4 – Size of the Steel Frame
While calculating the size of the frame, keep in mind to keep clearance from the floor and from the ceiling.
Step 5 – Pivot the Steel Frame
Weld a 1/4 inch plate at the pivot points and then weld bolts to provide extra strength. The steel frame should have 2 pivot points, mounted to the floor and ceiling respectively.
Step 6 – Ceiling Anchor
Ceiling anchor should span 3 joists. Use a brass flange bearing, ¾ inch, inserted into a hole in 2X2 box for the pivot point.
Step 7 – Floor Anchor
Use the similar procedure for the floor anchor as well. However, you can afford to have a smaller anchor, especially if you would bolt it to a concrete floor.
Step 8 – Position the Steel Frame
Now carefully position the frame and both the anchors. Use a plumb bob to verify that the frame is vertical.
Step 9 – Test the Swing of the Frame
After this, secure both the ends using bolts. Place a 500lbs weight on the frame by making people stand on it and test the door’s swing.
Step 10 – Build the Wooden Shelves
Now build the wooden shelves into the steel frame. The swinging shelf should be shallower to provide clearance.
Step 11 – Install the Trim
Install the trim all around the frame/door. The right trim should be fixed to shelf and the left trim should move along with the door.
Step 12 – Wooden Door Stop
Put on a wooden door stop to ensure that the door doesn’t float open or else the secret area of your house would no longer be secret!
