How to Build a Raised Bed using Landscaping Timbers
6 Pieces Landscaping Timber, 6 x 6, 4-feet long
6 Pieces Landscaping Timber, 6 x 6, 8-feet long
Shovel and Trenching Shovel
Gravel
Wheelbarrow
Drill and Drill Bits
Hoe
Sledgehammer
12 Metal rebar, 0.5-inch wide, 12-inches long
10-inch timber screws
Building a raised bed with landscaping timbers has many advantages for you and your garden. It makes it easier for plants to grow because the bed can be filled with richer soil than what is available naturally. Also, if you have back pain or spinal injuries, you will have an easier time since you won’t have to bend down to do your gardening.
Step 1: Setting the Frame
Get 2 pieces of 4-foot long timber and 2 pieces 8-foot long landscaping timber. Set them down on the portion of the garden that you want to be elevated. Form a rectangle on the ground, enclosing the portion that will be in the elevated box. Mark the inner and outer perimeter ground with a shovel or spade. Remove the landscaping timbers and you should now have two rectangular outlines on the ground, one inside the other. These are the lines for your trench.
Step 2: Dig a Trench
Make a trench by digging around the marked perimeter that you made on the ground. Make a 6-inch deep rectangular trench for the walls of the raised bed. Place the collected dirt in a wheelbarrow. Once you’ve dug up the perimeter, fill it evenly with 2 inches of gravel.
Step 3: Laying Down the Landscaping Timbers
Place the 4-foot and 8-foot timbers in the trench and line up the corners in such a way that they join together in a clockwise order. Now get your drill and make 1/2-inch holes every two feet in the wood. Get a rebar that is 1-foot long and use the sledgehammer to pound it through the hole into the soil. Keep pounding until the end is level with the timber.
Do this process to all of the holes and pound rebar into them. Place more 4- and 8-foot landscaping timbers on top of the timbers you laid down on the perimeter but now, set them around in a counter-clockwise order. Place 5 timber screws on each side in order to join the two layers of timber together. Make sure that you make an even distribution of the screws.
Step 4: Drainage Holes
Get your drill and make some holes on the sides of the landscaping timber that you just laid down. The holes should be approximately 1/2-inch wide. Drill just one hole on the side of the width of the frame and two holes on the side of the length of the frame.
Step 5: Finishing
Place the last pieces of timber on top of the ones you’ve already laid down. Lay these in a clockwise order once again. Secure them by driving timber screws again so they are properly joined to the existing landscaping timbers.
