How to Build Wooden Fireplace Surrounds
Fireplace with surrounding mantle
  • 5-15 hours
  • 50-500
Solid oak boards 1 x 8; 1 x 6; and 1 x 4
Solid oak mantle piece
1 x 10 board
1 x 8 board for the decorative effect
Crown molding
Finishing nails
1/2 inch screws
Hammer or nail gun
Drill
1/4 inch countersink drill bit
Wood filler
Wood glue
Masonry bit
Masonry screws
Circular or table saw
Jigsaw
Sander
screwdriver
1 x 10 board
Crown molding
Finishing nails
1/2 inch screws
Hammer or nail gun
Drill
Wood filler
Wood glue
Masonry bit
Masonry screws
Jigsaw
Sander
screwdriver
Nothing adds ambience like a fireplace in any room of your home, but it is the wooden fireplace surrounds around fireplaces that really makes them stand out as part of the interior design. An unsightly fireplace can be transformed with a little bit of work even the novice carpenter can accomplish. In addition to being a source of heat in the room, the fireplace can also become the focal point of the decor.
Step 1 - Measure the Size of the Fireplace
Since most municipalities have specific regulations concerning the distance any wooden structure can be from the firebox in a fireplace, it is important that you check the building codes for your area. Measure this distance as well as the height and width of the fireplace. Write down the measurements and take them with you to the home improvement store where you intend to purchase the materials.
Step 2 - Begin Making the Sections for the Fireplace Surround
Corner where crown molding meets
Saw out the boards you need for the sides of the fireplace surround. Cut two pieces each of the 1 x 4, 1 x 6 and 1 x 8 boards to the same measurement as the height of the fireplace. Sand them with the sander until they are really smooth when you rub your hand over them. Glue a piece of 1 x 4 on top of a piece of 1 x 6. Screw the pieces together with ½-inch screws, but do so from the back so that there won’t be any marks showing on the front of the surround. Repeat this for the other side with the remaining pair of 1 x 4 and 1 x 6 boards. Now, glue the sections you just made to the 1 x 8 boards.
Step 3 - Add the Crown Molding
Nail or glue crown molding on the sections. Do this on the sides where the boards are joined together. If you decide to nail them, use a nail gun and finishing nails because you can easily fill in the holes with wood filler before you paint the finished project.
Step 4 - Attach the Sides to the Wall
Determine how far out from the fireplace you want the sides to be. Mark the wall in this location. Use construction adhesive to glue the boards to the wall. With the masonry bit, drill two holes through the 1 x 8 board, about six inches from the top, and through the brick of the fireplace. Anchor the board in place with masonry screws.
Step 5 - Make the Mantle
Cut the 1 x 10 board to fit the measurement between the two side pieces. Make sure it fits snugly flat against the fireplace. Drill five holes along the top of this board, again making sure the bit goes through the brick. Screw it in place with masonry screws.
Step 6 - Decorate the Front of the Surround Top
Draw a design on the 1 x 8 board and cut it out with the jigsaw. Use the sander to smooth this board and glue it to the 1 x 8 piece you used as the backboard. It will cover up the holes you drilled to attach it to the fireplace.
Step 7 - Put the Mantle in Place
stockings hanging on a mantle
Drill ¼ inch holes in the mantle. Glue the mantle on to the surround and then screw it in place. Make sure you countersink the screws.
Step 8 - Finish the Wooden Fireplace Surround
Check over the surround to make sure there are no areas where you can see any imprint of nails or screws. If so, such as on the crown molding, use a small amount of wood filler on the tip of your finger and fill in the indentation. Wait for it to dry and paint or stain the surround to suit the décor of your room.
