How To Buy A Mortar Thin Set
When you are applying tile to the floor, you are obviously going to want to make sure that it will be durable, especially in choosing the right mortar thin set. Additionally, you will want to make sure that it adds more beauty to the home. There are many vendors that distribute mortar thin sets, which means that there are many different directions a person can go when finding something that has the right look. There are certain steps a person should take to make sure that they have made the right decision.
Using the Right Grout
Firstly, you need to know what color of grout that you will be using. There are a few different types, but it is wise to use gray grout if you are using dark tile. On the other hand, if you are using light tiles, you should go with white.
Latex or Sanded
If you are applying the mortar to cement, you should go with a sanded base. If your canvas is vinyl or some kind of wood, it’s best to invest on the latex based mortar thin set. You will also need to calculate how much you will need, so you do not buy too much. And lastly, consider your experience, as there could be more qualified people to handle the job.
