How to Bypass Garage Door Remote Opener Sensors
Sensors
Small object to test
There are a few different ways that you can go about bypassing the garage door remote opener sensors. Here are a few steps to help guide you.
Step 1 - Find a Spot
The first thing that you want to do is find a spot that you can move your sensors to. It needs to be somewhere that can accommodate them without having to unplug them. Pick a spot that is out of the way completely.
Step 2 - Move the Sensors
Next, you will want to keep the sensors hooked up to the wires and move them slowly so that they are both on the same side and next to each other. Line them up so that they are secure in the spot.
Step 3 - Test It Out
Finally, test them out to make sure that they are not tripping. You can do this by placing a small object under to see if it stops.
These steps should help you to bypass the garage door remote opener sensors. Be sure that when you are trying to accomplish this task, you keep in mind the safety of yourself and others around you and do not stand under the door or in the doorway while testing.
