How to Charge Golf Cart Batteries How to Charge Golf Cart Batteries
Charging the battery in your golf cart can be done quickly and simply. Most electric golf carts operate using batteries, and these can sometimes run out of power. Before your batteries run out of power completely, you should charge them up. You can have the batteries charged by a professional, or you can do it yourself. If you choose the latter, you will need some items such as the wrench, a battery charger, and some cables and connectors.
Charge Your Golf Cart Batteries
The first thing that you should do is check the manufacturers' instructions, and follow them closely. This will increase the likelihood of a good charge. While charging, you should ensure that the water in the battery fully covers the leaded plates inside. Unscrew the caps on your battery charger, and attach the cables and connections which will charge the battery. Ensure that you have the right connections for your golf cart battery by following manufacturers' recommendations. Plug the charger device into the battery using the cables, and turn it to On. You should leave your battery to charge overnight. After charging is finished, you should check that your battery is working, and then leave it to rest until it is next needed.
