How to Clean a Shower Head
Warm water
White wine vinegar
Empty spray bottle
Expendable toothbrush
Small scrub brush
Washcloth
Paper towel
If your shower head has recently fallen victim to mold or mildew deposits, you may be curious about how to clean the shower head. Due to the excessive amount of moisture shower heads accumulate, they must be regularly cleaned to prevent the formation of mold and mildew.
Step 1 - Remove Your Shower Head
While removing your shower head is not essential to the cleaning process, it will make the job a lot easier. To do this, firmly grip the shower head and proceed to turn it in a counterclockwise fashion until successfully detaching it. Once the shower head has been removed, set it down on a washcloth or paper towel for the duration of the cleaning process.
Step 2 - Produce Your Cleaning Solution
Now that you've removed your shower head, you're ready to mix your cleaning solution. Simply combine 1/4 cup of white wine vinegar with 1 cup of warm water inside of an empty spray bottle. This solution can prove invaluable when it comes to how to clean a shower head.
Step 3 - Apply Your Cleaning Solution
Having produced your cleaning solution, vigorously spray it onto your dirty shower head. After allowing the solution to set in for 15 to 20 minutes, give the shower head a thorough scrubbing with the aid of a small scrub brush or an expendable toothbrush. Once all grime, mold and mildew has been cleaned off, rinse the shower head under a warm faucet, then dry it with a paper towel or dry cloth.
The next time you're curious about how to clean a shower head, just remember to utilize these 3 easy steps.
