How to Clear a Clogged Central Heating Pipe
Your central heating pipe can become clogged over time. There are several ways to go about clearing the pipes. It is always a good idea to go about it the simplest way so that you will not have to be put out too much while you are doing this. This job itself can be a bit of a hassle if you do not know the right steps or have the proper tools. However, if you come prepared, then you will have to put forth minimal effort to get the job done.
Step 1 – Pick Product
There are several different products out there for you to choose from. It is all up to you on how much money you are willing to spend and how bad you think the clog is. Do you research and pick one that you feel comfortable with. Try not to go with the cheapest one if you think that the clog is bad, remember you will more than likely have to come right back up to the store to get more and end up wasting money.
Step 2 – Follow Directions
It is important that you follow the directions that come with these products. You will find that each product is different. They all usually have the same basic directions but may have a few different steps that could make a very big difference to the overall outcome of the project.
Step 3 – Prepare
In order to prepare for this product to do its job, you will first need to flush and drain your heating system. You will need to do this with regular water until it no longer foams. Once you have done this you will need to move on to what the directions on your product state. You will have a certain amount of time that it will need to set and a certain amount of time before you can try it again. Once it is time to try your heating system out again, you will need to drain and flush your entire system once again. Do this until the water is completely clear.
Step 4 – Clean Up Debris
There will more than likely be a lot of caked on debris that will need to be removed. This debris will build up over time and it could cause another clog if you allow it to get out of hand. You will need to isolate the flow to the return pipes that go into your heating circuit. Use your product as recommended while allowing to set for the allotted time. Once the time is up you will need to drain out your system while it is still hot. Once you have done this you will need to flush the system out with regular water.
When in Doubt
If you feel uncomfortable about the project at all then it is always a good idea to call a professional. This may also be necessary if the clog remains after you have done the work.
