How to Control Humidity in Your Home During the Winter How to Control Humidity in Your Home During the Winter
Dehumidifier
Moisture barrier fabric
Ventilators
Exhaust fans
Vapor barriers
Storm windows
If you would like to control humidity in your home, there are a number of methods you could try. Humidity is not only a health hazard, but also an encumbrance to comfortable living. Furthermore, it effects the house negatively by causing a number of unwanted effects, such as wet spots, mold and even structural damages. Here are some ways that may help you control humidity in your home during the winter months.
Step 1 – Basic Inspections
Start off by carefully inspecting your house. A number of factors may be increasing the level of humidity which can easily be tackled. For instance, if you have any appliances, such as water heaters or furnaces, you have to make sure that they are not increasing the level of humidity in the house by extracting into the room. Outside vents should be used to move moisture outside of the room. It is best to avoid having any plants indoors, since soil is a way of retaining humidity in the room. Otherwise, make sure to use moisture barrier fabrics so as to reduce the level of moisture in such areas. It is best to install a humidistat so as to be better aware of the level of humidity in your house. It will also help you to set it accordingly, to hopefully control humidity levels better.
Step 2 – Acquire a Dehumidifier
It will be helpful if you consider acquiring a dehumidifier. This will greatly help you to get rid of excessive humidity in your house. Make sure to check it regularly so as to remove the water that it absorbs, and enable it to work more efficiently.
Step 3 – Install Exhaust Fans
Bathrooms are one of the main sources of humidity since substantial amounts of water are used all the time. It is recommended that you install exhaust fans in your bathrooms, and to switch them on whenever you are going to spend time running water, mainly whenever you bathe or shower. A small exhaust fan can also be installed in the kitchen, ideally in the vicinity of the sink and the oven.
Step 4 – Ventilating
It is important to ventilate your rooms as much as possible. Apart from opening windows whenever the weather permits, you may also consider installing soffit vents in rooms where there are very high levels of humidity.
Step 5 – Install Vapor Barriers
Another helpful technique is to install vapor barriers in areas where you can reduce the amount of moisture that gets into your house.
Step 6 – Having Storm Windows
You may consider having storm windows rather than the usual window panes. By being slanting, such windows will reduce the impact of rain and dew from reaching the windows and having moisture sitting on your windows for a long period of time. This will greatly reduce the moisture and condensation effects, and consequently the humidity in your rooms.
