How to Convert Twin Beds into a King Size Bed
two twin beds next to each other
  • 1-2 hours
  • 30-60
Strapping chords
Sheepskin
Kings bed sheets
Strapping chords
Sheepskin
Kings bed sheets
It is easy to convert twin beds into a king size bed. If your stairway or door is too narrow to move a king size bed, or if you already have twin size beds not in use, this might be the perfect solution for you.
Step 1 - Bind the Box springs
Bring the box springs of your twin size beds together. The longer edges of each box spring should touch each other. Two box springs can rest on one king size frame or two separate twin size frames. Bind the box springs with a binder strap encircling the box spring assembly along the outer edges. You may have to tie two or three straps to make it sufficiently long.
Step 2 - Bind the Mattresses
Put the twin size mattresses on the box springs. Bind them with binder strap in the same way.
Step 3 - Close the Gap
Now close the crack at the junction of the two mattresses. You can use a strip of sheepskin, foam bed bridge or any other gap filler for this. Place it along the length of the crack. Attach the two ends of the strip to the existing strap around the mattress assembly, and that's it—your king size bed is ready for use.
If you're feeling ambitious, or looking for a different kind of space saving solution, try integrating your next set of twin beds into bunk beds!
