How to Cut Granite Tile Countertops How to Cut Granite Tile Countertops
Granite slab
Laser-sided saw
Diamond saw blade
Grinder
Plywood
Cutting granite tile countertops can be an easy task to accomplish. With a little patience and know how a person can get this job done very simply.
Steo 1 - Making Sure to Follow Safety Rules
Take a pair of heavy work gloves and place them on your hands and then place a pair of goggles over your eyes. A person who does this job will be working with a saw which has very sharp blades.
Step 2 - Preparing the Cuts
Purchase plywood to produce a template. This is necessary since a template will decide where the cuts will be. The template is made of glued together plywood which is then placed on top of the granite slab. Be sure that the templates are measured to ensure that the slabs are cut to the correct squares. A variety of shapes can also be made.
Step 3 - Cutting the Square Tiles
Cut the granite tile countertops by using the laser saw. The laser saw will make quick easy cuts and be sure that a new blade is used. This should be an easy task and when the cuts are made and are smooth the tiles can be cleaned and polished.
