How to Design a Cobblestone Driveway
Transit
Tape Measure
Landscape Paint
Graph Paper
Computer and Graphic Software
A cobblestone driveway brings back visions of old world roads and paths. Cobblestones are one of the earliest forms of creating permanent roads and walkways. These stones are made through cutting larger stones into rectangular or square shapes. Many of the older cities of the world have sections where there is still cobblestones on the roads. Homeowners today look to cobblestones as a way of creating a driveway that has both a rustic look, but also very durable for many years of use. Building a cobblestone driveway is quite a process that involves detailed planning, the right equipment, and lots of time. The first step to building the cobblestone driveway is to plan it out. Here are some different steps you can take to design your cobblestone driveway.
Step 1 - Take Measurements
Knowing what you have to work with will help you to design a great looking cobblestone driveway. To do this you will need to take a lot of measurements. Not only do you want the width and the length of the proposed driveway location, but you also want to take into account other areas. Give yourself several options so that you have a driveway that you will enjoy for a long time.
Step 2 - Allow for Sloping
One of the most important measurements to take is the overall length of the driveway. This is so you can calculate the elevation you need to set a slight slope into the grade. This slope is essential for the water to run off and not settle anywhere on the driveway. A transit is the best way to measure the land for the grade and the amount of slope you will need.
Step 3 - Draw Your Cobblestone Driveway
Once you have the measurements you can start to play around with the designs. Think about how you would like your driveway to look. Will there be any curves? Will it be straight? Will it be side at the beginning and narrow at the end? Or, will it be the reverse? Will you go to the garage, or straight to the door? Make a scale drawing of the driveway on graph paper for the best visualization.
Step 4 - Use Computer Graphic Software
One of the biggest helps that technology has given to homeowners is the use of computer software to aid in the design aspects of different projects. Use a computer software to help design your cobblestone driveway. You will be able to choose from many different options from the size of the driveway, the shape of the cobblestones, and the exact pattern you want to lay them out in. At the end you can print off a nice blueprint to follow.
Step 5 - Draw Driveway on Ground
With the help of your drawing, or your computer printoff, take to the driveway and start to layout the actual design. Landscape paint will help to visualize your new cobblestone driveway if this is a new driveway. If you have a gravel driveway now, use some cobblestones and follow your placement pattern to see if you will like the way it looks. If not, play around with the design until you find something you like.
