How to Design Wooden Staircases
Lead Image for How to Design Wooden Staircases
Whenever you are deciding on a wooden staircase there are several different factors that you should keep in mind. It is important that you have a complete design prepared in your head so that you will be able to make the job go much easier and smoother. The more prepared you are for your wood staircase, the better off you are going to be when it comes to putting it all together.
Kit vs. Scratch
The first thing that you are going to need to do is to decide if you want to build your stairs from scratch of if you want to get a kit. If you are concerned with a budget, then a kit is going to be the best way to go financially. It is also an easier route to take if you are not very skilled when it comes to building things of this nature. However, when it comes to building one yourself you will be able to make it exactly how you want.
Budget
Make sure that you have a budget in mind whenever you are getting started. You will need to keep in mind that a spiral staircase is very expensive. As previously mentioned, a regular staircase is going to be the least costly. However, if you are building a staircase from scratch, make sure that the wood and tools that you need are ones that you are going to be able to afford. You will need to keep in mind that all of these materials are going to add up so you should plan accordingly.
Wood Types
It's a good idea to get the type of wood you wish to use chosen before you do anything. The aesthetics of the wood you select will have a lot to do with the finished staircase that you get. Think about whether or not you want the wood to remain natural or if you'll want to stain it, or put carpet over it. These are things that you will need to think about so that you will be able to get the right type of wood for the job.
Measurements
You will need to get good and accurate measurements of the area that the stairs are going to go into. Keep in mind that some staircases are going to take up more room than others so if you are looking to fill a lot of space then you will want a spiral staircase whereas someone with limited space will need a regular set of stairs.
Number of Steps
You'll need to decide how many steps you want to have before you can go out and purchase the material. Think about how steep you want the stairs to be. How shallow or steep the stairs are will ultimately determine how many there will be.
