How to Design Wooden Sign Posts
Wood
Hammer
Chisel
Carving knife
Sandpaper
Wood burning pen
Clear varnish
Cleaning rag
Gloves
Facemask
Worktable
Wooden sign posts are used in a multitude of locations ranging from your office to jogging tracks. They are used to display notifications and need to be modeled to catch the public’s eye. Wooden signs have an advantage over metal signposts in a way that the former type makes the surrounding environment warmer and aesthetically pleasing. Making one yourself allows you to creatively add a personal touch to the signpost and makes up for an excellent hobby. To find out more about how to make your own sign post, read the steps described below.
Step 1 – Take Appropriate Precautions
Woodwork always involves tools like carving knives and hammers that can cause injuries. Always practice extreme caution when using these tools to avoid a trip to the hospital. Keep a pair of thick rubber gloves at your disposal to use when hammering and sanding the wood. Make sure that the worktable is stable for woodwork as an unstable table can decrease the efficiency of your work. Make sure that you have a facemask before sanding the wood to protect your lungs from wood dust. This and the use of gloves will ensure that you are safe from a possible allergic reaction. With these precautions in mind, move on to the next step.
Step 2 – Obtaining the Wood
The cheapest method of obtaining the wood for the signpost is collection from the woods. Wood that has been freshly picked from the forest provides a more fresher and natural touch to the signpost as opposed to wood picked at the lumber store. Be sure to pick out medium sized logs that haven’t been eroded or cracked by environmental factors. After this is done, read the next step to learn more about processing the wood.
Step 3 – Processing the Wood
Before you can begin with the construction, you will need to cure the wood to avoid decay. Soaking the wood in salt water for a day followed by sun drying can effectively cure your wood. You will need to decide whether to shave off the bark from the logs or to let it remain as it is. This decision depends on the design of the signpost that you have planned out and needs to be made before the curing process.
Step 4 – Cutting and Shaping
Cut the wood into the desired measurements using a handsaw and sand to remove any rough bits before carving. Typically, a chisel or carving knife is used to carve a design for the signpost but you can use any carving tool that you prefer. After the design has been carved use a wood burning pen to mark the wood with letters and numbers.
Step 5 – Polishing and Finishing Up
Use clear or stained varnish – depending on your preference – to polish the wood so that it looks more presentable. Wood wax can also be used in place of polish to highlight wood grains. Apply sparing amounts of the preferred polishing agent and buff with a soft cleaning rag until the desired amount of shine is acquired.
