How to Detect an Ammonia Leak in Your Apportion Refrigeration Unit How to Detect an Ammonia Leak in Your Apportion Refrigeration Unit
Ammonia Detection System
Absorption refrigeration is something that you will need to check for ammonia leaks. This can be a very serious problem that cannot go unnoticed as it could cause severe health issues for all those that come into contact.
Step 1 – Find the Right System
There are several different types of ammonia detection systems out there. You will find that it is important to do your homework to make sure that you find one that is going to be able to do the right job for you. Consider price as well as the reputation of the brand you go with.
Step 2 – Maintenance
One of the best things about most ammonia detection systems is the fact that they are pretty easy to keep up with maintenance wise. It is recommended that once a year, you have it tested to make sure that it is still in working order. Doing it more than that is up to you.
Step 3 – Options
There are some options that can go along with your system if you choose. You will find that a back up battery is something that you should consider. You should also look into a remote sensor.
