How to Enclose a Deck
Screening
Nuts and bolts
Border Trim
Staple Gun
Prefabricated Lattice
Posts
Screen Doors
Screen Door Paneling
A deck is something that can be used as an extra room in your home. You can use it for entertainment, as a dining room or even as a kitchen to grill on. No matter what it is you wish to use your deck for, you will find that it can be very limiting when it is not enclosed. Enclosing a deck can ensure that you will get much more use out of it and will be able to use it without the worry of weather and bugs. It does not have to be a difficult task to enclose a deck as long as you know the necessary steps that you will need to take to get the job done quickly and effectively.
Step 1 – Decide on Your Surroundings
There are several ways that you can go about enclosing your deck. You will need to begin by trying to decide what type of enclosure you are looking for. You will also need to decide how much work you are willing to put into this job, there are screen house kits that are available if you choose to use screens. Most screen house kits can be put together in a matter of an hour or two.
If you choose to make your own, then you will have to put much more money, thought and time into your deck. It is important that you are aware of your options and make the decision that is right for both you and your deck.
Step 2 – Screen House Kits
If you have decided on a screen house kit, then there are four basic designs that you will have to choose from. There are two that can stay up year round and two that are meant just for the summertime. Be sure that you read about each one thoroughly so that you are able to get a good idea about which one will best suit your needs. Read the instructions carefully while assembling.
Step 3 – Do It Yourself
If you wish to build the area yourself, you will need to first get the measurements of your deck. From there, you will need to begin to make a design for the basic structure of what it is you want to make. Get posts and attach them at each corner of your deck. This will help to support the panels for the screen door. For additional support, add intermediate panels.
Step 4 – Build
You will need to get your prefabricated lattice secured to your posts as well as the roof. A staple gun will need to be used to allow the screening that is under the lattice to enclose your roof. If you do not wish to use lattice, vinyl will also work well.
Step 5 – Screen
Attach your screen door paneling to your posts. You will probably want to use border trim along the top, which will provide additional support.
