How to Extract a Broken Bolt from a Motorcycle Engine Block
WD40
Mole/Vice Grips
Stud Removal Tool
Drill
Several Drill Bits
Bolt Extractor
Number of Mechanic
If there is a broken bolt that is lodged into your motorcycle engine block, then you will find that it can be difficult to extract it. However, there are a few different things that you can do to try to get rid of the bolt without doing damage to any of the surrounding areas or causing the nut to become further lodged into the engine block. You will simply need to keep a few things in mind and work slowly and carefully.
Materials Needed:
WD40
Mole/Vice Grips
Stud Removal Tool
Drill
Several Drill Bits
Bolt Extractor
Number of Mechanic
Step 1 – WD40
Typically, whenever this happens, it is because the head has broken off and the actual shaft of the bolt is sticking out of the block. There is usually a reason why the bolt broke in the first place. It is a good idea to go ahead and spray WD40 or something similar in the area to make it easier on yourself. Once you have done this you are ready to move on to the next steps.
Step 2 – Grips
With the grips, you will need to get a tight hold on the part of the shaft that is exposed. You will need to move it around, forwards and backwards, try to loosen it as much as possible. Once you have got it to move around, you should be able to gently persuade it out of the area that it is stuck in. Once you have done this, you are finished. However, it may not always be this easy.
Step 3 – Drill
If the shaft is not exposed and is broken flush to the surface, then you may need to get a drill to go down to the center. Use your stud removal tool to get it out. If you are unable to do it with this tool, then you will more than likely have to drill down to your bolt using a drill. You will gradually use bigger drill bits as you go. Make sure that you use a reverse spiral on it. You will do this until the old bolt has collapsed and fallen out. Once this has happened, you will need to get a blind tap down onto the hole so that you can clean the thread out completely.
Step 4 – Bolt Extractor
It is also worth trying to use a bolt extractor for this task. You will be able to find them at most auto parts stores as well as any hardware store. This is something that will only work if the shaft is exposed at all. If it is not, then you will need to drill it as previously mentioned. If you do not feel comfortable doing this, then simply take it to a mechanic that will be able to do this task for you. They will more than likely weld out surrounding area and remove the bolt for you. If at any time you begin to feel as though you are in over your head, then you should immediately contact a mechanic to prevent further damage.
Step 1 – WD40
Step 2 – Grips
Step 3 – Drill
It is also worth trying to use a bolt extractor for this task. You will be able to find them at most auto parts stores as well as any hardware store. This is something that will only work if the shaft is exposed. If it is not, then you will need to drill it as previously mentioned. If you do not feel comfortable doing this, then simply take it to a mechanic that will be able to do this task for you. They will more than likely weld out the surrounding area and remove the bolt for you. If at any time you begin to feel as though you are in over your head, then you should immediately contact a mechanic to prevent further damage.
