How to Fix a Noisy Dishwasher How to Fix a Noisy Dishwasher
Listening to a noisy dishwasher can not only irritate you but it can become quite frustrating to deal with. If your dishwasher has suddenly started to make noise, there could be a number of causes as to why. The most common is a broken water inlet valve, worn motor and/or blades, or a worn pump. Understanding how to fix your noisy dishwasher may require that you replace one of these parts. If you are unsure how to go about replacing the part you may want to hire a professional..
Easy Fixes
Before you can accurately fix a noise dishwasher, you must first narrow down where the noise is coming from. Here is a list of steps to check.
  • Test the inlet filter screens for damage. If it is damaged remove the filter screen and replace it with a new one.
  • Check the motor and mounts - If the motor is not properly mounted, it will rock back and forth causing noise every time the dishwasher runs.
  • Check the spray arm for damage- If the spray arm is damaged it can cause noise while it spins. If you notice that the arms is bent or broken, replace it immediately.
