How to Install a Car Parametric Equalizer
16-Gauge Wire
Black Tape
Screws
Screwdriver
A car parametric equalizer allows you to control or maintain frequencies, bandwidths and amplitudes (also called parameters) that establish the response of your car’s audio equipment. It is a popular way of upgrading a car’s audio device for those who take music seriously as it enables them to attain the precise balance that they desire. In other words, this device takes care of the frequency bands and saves you from the hassle of adjusting for every special band. Follow the steps below to install a parametric equalizer in your own car.
Step 1: Decide the Place for Installation
Before you begin with the installation, decide the precise place where you want to position your equalizer. That will depend on your preferences in terms of comfort and usage and also vary according to your car’s model. If you decide to set it on the dashboard, keep in mind that you may have to make a unique customized holder for it.
Step 2: Hook Up the Gauge Wire
Once you have decided on the place, ensure that your car’s stereo or audio system is fully installed. Once done, use a 16-gauge wire to hook up to your panel of fuses for power input. To do so, you may have to detach the screw around the equalizer; if you are unable to do so, go forward by creating a hole for it to pass through. However, once you have positioned the wire through, don’t forget to replace the screw you removed.
Step 3: Use the Wires
Proceed by locating the stereo’s primary unit. Take it out as well as the cover at the edge of the wire connected to this stereo’s primary unit. Now, use another wire (longer in length than the one you previously used) to link the stereo to your parametric equalizer. Take off the cover towards the edge of this wire too, and tie these 2 wires together with black tape.
Step 4: Relay the Wires
Locate the wire going from the audio unit to your parametric equalizer, which should turn the power on your system and relay it. Tie down this wire with whatever equipment or device in your car you think is appropriate. Then fasten the RCA cables from the dash unit to the preamp passage. Again, use black tape to fasten the cables together so as to secure them so they willnot spread apart from one another. Finally, relay them inside your car’s dashboard to the equalizer’s creek.
Step 5: Final Touches and Check Up
Put the parametric equalizer back together with the amplifier using RCA cables running from the amplifier’s outlets into the equalizer’s creek. Secure all the wires that you have installed or attached together, and see to it that the newly installed device is working effectively. If it is performing correctly, put the dash unit back in place.
