How to Install a Cyclone Fuel Saver
Cyclone Fuel Saver
Screwdriver
The cyclone fuel saver is a great contraption that helps you save precious fuel when using your car. As gas prices skyrocket, this device will give you a lot of savings on fuel and can also add a little more horsepower to your ride due to its efficient fuel burning capabilities.
Step 1: Detaching the Air Box Hose
Locate your vehicle’s air box. Unscrew the air box hose by getting your screwdriver and undoing the screw that connects the hose to your air box. Once removed, detach the hose from the air box.
Step 2: Attaching the Cyclone Fuel Saver
Attach the fuel saver by connecting it into the inlet hose and make sure that the connection is tight and snug. It should fit right into the tube and must be the exact size. There are many types of cyclone fuel savers, depending on each car model so be sure you buy the correct one for your vehicle.
Step 3: Reattaching the Hose
With the fuel saver attached securely into the inlet hose, return the hose to its original position by fitting it back into the air box. Reattach the clamp that goes around it and secure it by putting back the screw that holds the hose to the air box. Your cyclone fuel saver is now installed.
