How to Install a Dual Fuel Range How to Install a Dual Fuel Range
Dual fuel ranges have grown in reputation as the importance of proficient model home kitchens has increased. Installing dual fuel ranges can provide cooks with the benefits of more than one kind of fuel in preference to the restrictions of a solitary fuel range.
Duel fuel ranges, known as duel fuel stoves, have developed into a well-liked option for people whose budget and home design can contain them. Installing dual fuel ranges is easy provided you follow carefully the instructions indicated in the manual.
Step 1 – Familiarize Yourself with Fundamentals of Dual Fuel Ranges
The dual fuel range is a stove which combines various fuels for cooking: electricity and gas. Gas is a clammy heat, and it provides enhanced temperature regulation for top-of-the-stove cooking. Great chefs tend to favor gas cooktops. Gas-fueled cooking has a lesser operating cost compared to electric-fueled cooking, thus by using a gas-fueled cooktop one possibly saves on operating cost. The oven is typically operated by electricity.
Step 2 – Install Dual Fuel Range
Clean and check the area where the old stove was placed. Ensure you have new electric lines for the oven. Inspect the quality of pipes for the gas source. Usually, dual-fuel ranges work with the existing 120 Volt outlet, so no need to have a specialized outlet for it. You need to ensure that the gas pipes from the source to the cooktops are firmly and safely fastened. Follow other reminders indicated in the owner's manual to ensure everything was set up correctly.
Step 3 – Install Gas Hose
If your home has no basement, the shutoff needs to be along the wall at an access panel’s back. You need to take out the cap of the gas line using an adjustable wrench, if a gas range was never used before. Next, wrap the fitting on top of the stove while the gas pipe is coming up through the floor using Teflon tape. Screw a flex hose end to the fitting along the gas stove, then tighten it using an adjustable wrench. After this, screw the other flex hose end onto the gas pipe coming up via the floor and tighten it using the wrench. Switch on the dual fuel range gas supply.
Step 4 – Take the Final Considerations
When it comes to selecting among various kinds of fueling for your range, always consider your safety while cooking. Also, in existing houses the kitchen design may limit your choice either to electricity alone or to gas alone as your cooking fuel. On the other hand, some existing houses do have the capability for dual-fueling of the preferred range. Budgeting also offers a huge consideration: dual fuel ranges include higher purchase costs as well as higher maintenance costs than ranges which are either electric-fueled or gas-fueled only. Installation of the dual fuel range is a straight-forward job, which is normally guided by the manual provided by its manufacturer. Typically, the only concern of the dual fuel range purchaser is the piping for the gas source and the wiring for the electricity line.
