How to Install a Kill Switch in a Car
Wire wraps
Soldering iron
Solder
Voltmeter
Electric wire
Wire strippers
Screw driver
One way to keep your car from being stolen is to have a kill switch installed in your car. A kill switch disables the connection to the ignition. This prevents the car from starting.
Since new cars rarely are manufactured with these switches, you'll need to have a car mechanic install one for you or install one yourself. Here's how you can do it.
Step 1 - Gain Access to Your Ignition Switch Wires
A tan SUV.
To install your kill switch you'll need to connect to your ignition switch wiring. This means you'll need to gain access to them and to know which wires to connect your switch to. To get this information, check your user’s manual or call your car dealer's service department. To access these wires, remove the panel you find wrapped around your steering wheel.
Step 2 - Choose a Hiding Place to Mount Your Switch
Mount your switch inside your car where a car thief is least likely to find it.
Step 3 - Connect Switch Wires
A black car on the web.
Cut a length of electrical wire long enough to run from your switch to your ignition wires and connect one end of them to your switch. Sever the two ignition switch wires used to start your car. Connect these wires to the wires you attached to your kill switch. Test your switch by starting your car with the switch in the "on" position, then test with it in the "off" position.
By following these three easy steps, you can install a kill switch in your car and prevent it from being stolen. You can also install a remote kill switch.
