How to Install a Mailbox Post
Mailbox Post of your choosing
Post Hole Digger
Concrete Mix
Wheelbarrow
Sand/Gravel
Level
Tape Measure
Installing a mailbox post is actually a trickier job than most people think. There are several very important things that must either be done or at least taken into consideration before you simply dig a hole and shove a post in. Below are some basic steps to help you with the installation of your new residential mailbox.
Step 1 – Talk To The Authorities
There are regulations regarding the placement of a US mailbox that must be adhered to, though nothing specific as far as height or distance from the curb. According to regulations put in place in 2004, your mailbox has to be approved by the post office and set to such a distance and height that the postal carrier does not have to leave their vehicle. As a guideline for placing your mailbox, many people use the standards the post office had prior to 2004; a vertical height from the road to your mailbox had to be between 41 and 45 inches, with the outside edge of the curb or road to the mailbox between 6 and 8 inches.
You should go over your specific plans for your mailbox with a clerk from the post office to ensure your new mailbox will be considered deliverable.
Also, check with city and/or county records to ensure that there are no power lines, gas lines, etc. running underneath the spot you plan to put your mailbox.
Step 2 – Prepare Your Hole
Use your post hold digger to dig the hole roughly 2 feet down, or as deep as recommended for your specific mailbox post. Dig an extra 4 or 5 inches, and fill the extra space with sand or gravel; this will allow water drainage and help prevent water damage over the years. This should be done for ANY wooden post, even such wood as Cedar, which is reputedly resistant to such damage.
Step 3 – Concrete
Use your wheelbarrow to get your concrete mixture ready, following the instructions on the concrete’s bag.
Step 4 – Placing Your Post
Place your post in the hole, using a level to keep it plumb. Pour or shovel the concrete in small amounts at a time, and continue to re-check the post to ensure that it stays level. If you like, you may fill the concrete all the way to the surface, but this tends to be unsightly. It is better to leave the top of the concrete about 5 or 6 inches from surface level; this will be plenty to hold your mailbox in place.
Give your concrete at least 24 hours to dry, or however long specified in the instructions. Once dry, if it was left below surface level, fill in the rest of the hole with dirt and tamp it down.
Step 5 – The Mailbox
Go ahead and attach the mailbox of your choice. Double check with your tape measure to be sure that it sits at roughly the correct position for the mailman.
