How to Install a Pivot Hinge How to Install a Pivot Hinge
A pivot hinge is a hinge used when installing a door. This is what allows the door to stay in place, and also allows the door to open and close.
Installing a pivot hinge is quite easily. Follow the few easy steps below to learn how to do this very fast, and very easy DIY project.
Step 1 - Template
After you have purchased the right hinges, you will want to take the template that is included in the packaging, and use it to form your outline of where you will be placing the hinges.
Step 2 - Prepare and Drill
Using your template, you will want to prepare your area.Do this by sanding any areas of the door jamb to make it even and smooth.
Step 3- Install
Take out the rest of the items contained in the packaging, and insert them according to the template. Use the template to place your hinge in the correct area. Use the prepared holes on the hinge to place your screws.
Use your drill to secure the screws into place. Make sure that the hinges are even. If you have followed your template, this should be no problem.
Now, all that needs to be done is to hang your door.
