How to Install Brick Flooring
Brick flooring
Wet saw
Grinder
Tape measure
Adhesive
Chalk line
Concrete board
Trowel
Nails
Hammer
Brick flooring can provide you with a beautiful look in almost any room in the house. You can also install it outside for a nice touch to your patio. If you are going to install brick flooring, you want to make sure that you understand how to do the job properly. Here are the basics of how to install brick flooring.
Step 1: Determine How Much You Need
First, you'll want to measure the area in which you are going to install the brick flooring. Take your tape measure and get the length and the width of the area. Multiply the two numbers together to get the exact square footage of the room. Then you will want to add approximately 10 percent to that number so that you will have enough for waste.
Step 2: Plan the Layout
The next thing that you will want to do is plan the layout. There are several different patterns that you could do with your brick flooring. You could utilize a straight lay, a brick pattern, or a herringbone pattern among others. It will usually be to your advantage to draw out a diagram so that you can see how the flooring will lay out when you are done. Spend some time planning so that you can get a good picture of what you want to accomplish.
Step 3: Prepare the Floor
You will need a solid subfloor to attach the brick flooring to. If you have a concrete subfloor, you can attach it directly to that. If you are dealing with a wood subfloor, you are going to need to put some concrete board down on top of it. Put some adhesive on the bottom side of the concrete board and then nail it down to the wood subfloor.
Step 4: Determine Starting Point
You will then want to determine where you are going to start laying the brick flooring. In many cases, you will want to center the brick flooring in the room. You can do this by measuring the center point of each wall and snapping a chalk line in both directions. This will divide the room into four quadrants and then you can focus on one at a time.
Step 5: Lay the Brick Flooring
At this point, you can start laying the brick flooring. You should be able to apply some of the adhesive to the floor with your trowel. Make sure to smooth the adhesive out with your trowel. Then press a brick down into the adhesive firmly. Press another brick down directly next to the first brick according to your pattern.
Step 6: Making Cuts
When you get to the edge of the space, you are going to need to make cuts in the appropriate dimension. Measure the size of brick flooring that you need and then use your wet saw or a grinder to cut the piece that you need.
Step 7: Finishing Up
Once you have the brick flooring laid, you will want to allow the adhesive to dry overnight before walking on the floor.
