How to Install Steel Fence Posts
steel fence acting as a park barrier
  • 5-10 hours
  • 1,500-3,000
Concrete
Steel posts
Post-hole digger
Wires
Stakes
Hammer
Leveling tool
String
Concrete
Steel posts
Post-hole digger
Wires
Stakes
Hammer
Leveling tool
String
Without steel fence posts, a fence won’t be as sturdy as it could be. Fences, used for various boundary markers, are also used to block access, prevent theft and trespassing, and keep animals from wandering off. No matter why you're installing a fence, install steel fence posts first with this simple guide to ensure your fence has sturdy, long-lasting support.
Step 1 – Select and Purchase Posts
Choose between different types of steel fence posts. Some posts have tops and ends shaped like a “T,” “Y,” or a star.
In addition, decide how wide you want each post to be. This decision will depend on the length of the fence you will install and the distance you want to leave between one post and the next. Keep in mind that posts should be about 2-feet taller than the height of the fence that they will eventually support. After finalizing your decision, purchase the appropriate number of posts.
Step 2 – Mark and Inspect Post Spots
Next, mark each spot where a post will be placed. Measure an equal length between one post and the next, depending on how far apart you want them and the length of your fence.
Also, depending on the ground type, you may have to shovel or remove rocks to ensure each post spot is level before installing the supporters.
Step 3 – Dig a Hole in Each Spot
Now, dig a hole in each spot where a post will be placed. Use a post-hole digger to speed up the process. Each hole should be at least 2-feet deep.
Step 4 – Insert Stakes in Each Spot
Drive a small, thin metal post in the ground in each spot to serve as a stake where a steel post will be fixed.
Step 5 – Run a String Around the Area
Next, run a string around the area where the fence will be to identify any obstacles in the way. Remove the obstacles before continuing.
Step 6 ­– Fill the Holes
Start filling each hole with gravel or dry cement. Fill the holes up about 2/3 of the way.
Step 7 – Insert the Posts
Insert a post into each hole. Press each one down, so that the gravel will surround it. At this point, the posts should already feel secure, though you have only “plumbed” the posts. Use a leveling tool to check whether the post is fixed vertically well, or if it’s slightly tilted. Ensure all are perfectly vertical before moving on.
Step 8 – Add the Cement Mixture
Mix the cement and pour it into the remaining area in the holes. Let it dry completely before touching it for long-lasting stability.
Step 9 – Enhance Support
To enhance the post supports, anchor the post with more stakes or use wires around the base of the posts. This step is optional, but it can make the difference between a shaky fencing system and one that's long-lasting.
While you can install any type of fence with your steel fence posts, install matching steel fencing for the most stability and the best aesthetics.
