How to Install Travertine Pavers on Concrete How to Install Travertine Pavers on Concrete
Travertine pavers give any homeowner the opportunity to own a patio, sidewalk or driveway that looks as if it were right out of a cathedral. Travertine pavers can add value to the home by being aesthetically pleasing. If you have a concrete patio, sidewalk, driveway or walls, you can make them look much better with travertine pavers. Installing travertine pavers on top of concrete saves you money while increasing value. The following article will show you how.
Step 1 – Clean the Concrete
The last thing you want is to have dirt and other debris sealed into mortar. It will not be visible, but it can cause the travertine pavers not to set properly. Sweep away any dust that may be on the surface of the concrete. Mix a few drops of soap into the water reservoir of a power washer and then spray down the concrete. Rinse out the reservoir, fill it with clean water and then rinse down the concrete. Allow the concrete to air dry. If this is inside the home, you could use a dehumidifier to hasten the drying process.
Step 2 – Apply Mortar
With the concrete dry, you can begin applying the mortar to the concrete. Since both concrete and mortar are porous, they will bond together. Install the mixing attachment to the drill and, using the instructions with the mortar, mix it in the bucket. You can also buy mortar that is already mixed. Always begin at the inside corners of the project. Apply the mortar to the concrete using the trowel and being generous with the amount that you use. Work in small sections so you do not give the mortar much time to begin its drying process. Use the trowel to spread the mortar out over the concrete as well as to give it some texture.
Step 3 – Place Travertine Pavers
Once the mortar has been spread out over the concrete, you can begin laying the pavers. Place the pavers in the corner, first making sure they are tight against the wall. If doing a driveway or sidewalk, then add extra mortar to the outside edge to compensate for the spreading of the mortar. Once the paver is in place, press down on it while wiggling it from side to side. This helps to spread out the mortar as well as allowing it to attach to the travertine pavers. Place the next paver, butting it up against the last. Continue adding mortar and pavers in this fashion until they are all placed.
Step 4 – Clean Up
As you are placing the pavers, you will notice mortar being expelled through the seams. Use the trowel to remove this excess mortar and place it back in the bucket for use later on. The mortar needs to cure for at least a full day prior to being walked on. It will be at least a week before the mortar is fully cured.
