How to Join Wood Countertops
Screwdriver
Screws
Glue
Set square
Saw
If you are trying to fit wood countertops in your kitchen or work room, then you may be wondering how to get the perfect join on your tops. Wood countertops need to be worked on in order to get the best fit for your design, so you will need to make a good angle in order to ensure that they fit together perfectly.
Step 1 - Make the Angles
If you want to make the wood countertops fit correctly, you will need to use your set square then you can get the two sides of your countertop cut to the same angle. Once you have cut the side on one half of your countertops, you should then measure the same angle on your other. Put them together, and then use your saw to make both sides of the angle fit together without leaving a seam.
Step 2 - Fit the Countertops
When you have cut the countertops ot the correct angles, you will then need to put the countertop above the bases you will be using to support them. Slide the two countertops towards each other, and then use a temporary screw to hold them in place. Apply a layer of glue, and leave to dry. When the glue is dry, remove the screw and fix the countertops to the bases.
