How to Lay Outdoor Grass Carpet
An outdoor grass carpet may improve the appearance of your yard in every season. It may be installed on various surfaces and you only need a few materials and tools.
You Will Need:
- Carpet glue
- Paint roller and paint pan
- Measuring tape
- Scissors or cutter
Step 1 – Measure the Area
Establish where you want to place the grass carpet and measure the area, so that you know how much carpet you need. The place should be cleaned, so that the glue will adhere better to the surface.
Step 2 – Measure and Cut the Carpet
Measure the carpet and cut the size you require for your space. If you need several smaller portions of carpet, cut these. Deal with one at a time.
Step 3 – Apply Glue
Mix some glue in a paint pan. Apply glue on the back of the carpet. Use a paint roller to make your job easier. Make sure you cover all areas of the carpet.
Apply glue on the surface where the carpet is applied.
Step 4 – Place Grass Carpet
Put the grass carpet on the area that needs to be covered. Have someone help you if the carpet is larger. Press on the carpet and allow the glue to dry.
