How to Maintain a Stenciled Concrete Floor
Dishwashing Liquid
Nylon-Bristled Brush or Push Broom
Garden Hose
Leaf Blower
Pressure Washer
Sealant
Anti-skid Solution
Nap Roller
Stenciled concrete is inexpensive and adds stylishness and elegance to the original concrete floor. The concrete can be stencilled to look like stone or brick for your outdoor patio. If you want to use it for indoors, you can incorporate more elaborate designs. The maintenance needed for a stenciled concrete floor is relatively low. You just need to keep the concrete surface protected and clean. This type of concrete flooring is a beautiful addition to any room. With proper care and maintenance, your floor can last for many years to come. Outlined below are the steps needed to maintain your stenciled concrete floor.
Step 1 – Clean the Surface
Clean the surface by sweeping periodically. This is to prevent any debris, dirt or foreign particle buildup.
Step 2 – Wash the Surface
Wash the floor’s surface with a nylon-bristled brush and dishwashing liquid. Wipe spills, if any, and scrub the stains using this method too. After scrubbing the stains thoroughly, use a garden hose to rinse well. Allow the surface to air dry for 24 hours. For faster drying, use a leaf blower to dry the surface.
If the whole stenciled concrete floor needs to be cleaned thoroughly, use a push broom and dishwashing liquid to scrub. You can also use a pressure washer to clean the floor effectively.
Step 3 – Apply Sealant
When the stenciled concrete floor was constructed, sealant was applied to protect the floor from damage caused by the water, sun and dust. Sunlight may cause the stenciled concrete floor’s color to fade slightly. Applying sealant to it can revive the richness of the colors efficiently.
Mix and stir the sealant and anti-skid solution thoroughly. Apply the solution with nap roller to the concrete’s surface, making sure that the solution is stirred periodically to ensure that the anti-skid remains mixed with the sealer. Allow it to dry for 24 hours before walking on it again.
Apply the sealant solution regularly to protect the surface. Apply the sealant after 6 months of initial construction. Then, apply the sealant subsequently every 2 to 3 years. Be sure to apply the sealant mixture after you have cleaned the surface in step 1. It is worth noting that the best time to apply the sealant is spring or fall, when temperatures range between 55 to 90 degrees F. You can apply it in the mornings or evenings, during summer.
Step 4 – Protect the Surface
Protect the stenciled concrete floor by making sure that it is protected from scratches by furniture. Install plastic glides at the bottom of the furniture to prevent scratching the floor. If you have potted plants, use dishes under the pots. This is especially crucial if you use lots of plant fertilizers throughout the year. Doing so will prevent water and soil from saturating the floor, creating a stain which could prove difficult to remove.
