How to Maintain Pool Deck Paver Lights
Paver lights in your pool deck not only add aesthetic effects to your yard but also give sufficient lighting as you swim in your pool or just hang out on your deck. Paver lights, when strategically placed in your pool deck, can give it an ambiance of an island paradise at night. Therefore, it is a must that you take good care of your pool deck paver lights in order to maintain the beauty and appearance of your deck.
Materials Needed:
- Cloth for wiping
- Glass cleaning solution
- Small paint brush
Set a Monthly Cleaning Time
Always set a specific day of the month for your pool deck paver lights' monthly cleaning. The cleaning must be done monthly because paver lights are exposed to the elements. Dirt and even dead insects can easily build up inside your paver lights. Depending on the model of your paver light, you need to remove the glass. Wipe dry the inside of the light. You can also make use of a small paint brush for hard to reach areas. After that, you also need to clean the glass cover. Any glass cleaner will suffice. It will give your glass cover a good shine which looks just like new. Lastly, after cleaning, replace the glass cover securely.
