How to Mix a Natural Procelain Tile Cleaner
White vinegar
Water
Liquid detergent
A bucket
Cleaning cloths
You can make your own natural porcelain tile cleaner from items you will find in your cupboards at home. Vinegar is a common natural antibacterial product that cleans and deodorizes. However, it can damage types of stone such as marble and granite. Avoid using vinegar around these types of stone materials.
Step 1 – Mixing the White Vinegar with Water
Place a bucket into the sink and fill it with water. The water should be warm enough to clean without being too hot to use comfortably. Fill the bucket with two gallons of warm water. Add a ¼ cup of white vinegar. Mix the vinegar into the water until the solution is completely combined.
Step 2 – Mixing a Degreasing Solution
Fill a bucket with two gallons of warm water. Add one large squirt of liquid detergent to the warm water. Mix the water and liquid detergent solution until the water is soapy. Use this degreasing solution on any area that has a great deal of dirt or grease.
Step 3 – Applying the Natural Cleaning Solutions
Apply the degreaser with a cleaning cloth before you use the vinegar and water solution. Once the grease has been removed, rinse the area with clear water before you apply the vinegar and water.
