How to Paint a Metal Spiral Staircase
4-12 hours
Intermediate
- 200-150
Once you have your metal spiral staircase prepped for painting, it's time to apply the paint and the metal finish.
Step 1 - Apply Metal Primer
After cleaning the metal, dry it off completely before you start priming it. To apply primer your metal spiral staircase, put a ladder parallel to your spiral staircase then use the ladder to reach the upper areas of your metal staircase. Do not use the staircase while applying primer or paint on it.
For best results, you need to use both etch primer and high build primer on your metal staircase. Start by applying a light etch primer directly into the metal spiral staircase. Carefully apply the primer from the top to the bottom of the stairs. This way, you will be able to catch most of the drips and smooth it out on the surface of the metal. After applying etch primer, let the staircase dry completely before you apply the high build primer.
You need to apply at least two coats of high build primer on top of the etch primer. To make sure the high build primer sticks to the etch primer, apply one coat of primer and then let it dry completely. Pay close attention to hard to reach areas when applying the primer and make sure you do not miss a spot. Repeat the process until you achieve the desired result.
You may need to move your ladder around the spiral staircase to reach all the areas that need priming and painting. When moving your ladder, make sure you put it in a secure position before you climb on it.
Step 2 - Smooth the Dry Primer
Once the primer is completely dry, get a piece of wet sandpaper to smooth out the primer. Use a 600-grit to smooth out the surface then use an 800-grit sandpaper to achieve a fine finish. When sanding the primer, rub the surface gently and try not to remove too much primer to avoid weakening the foundation of your paint.
Step 3 - Clean the Staircase
After sanding the primer, clear your staircase again. You may use a damp rag to wipe off dust and particles from the staircase. After wiping off the staircase, let it dry completely.
Step 4 - Apply the Paint
When applying paint, start at the top of your stairs. Then work your way down to the bottom. You may use paint rollers or paint brushes to apply the paint. For a finer finish, you need to apply about three coats of high gloss enamel paint to your stairs. Apply only light paint coatings then let each of the paint coatings dry or become tacky before you apply another coat. To avoid uneven coloring, apply each coat at one time only.
Step 5 - Apply Polish or Sealant
Once the paint coatings have completely dried up, add a coat of polish or sealant on top of the paint. Let the polish or sealant dry completely before you use your stairs.
Step 6 - Remove the Covers on Your Floor, Furniture, and Fixture
After you are done painting your metal staircase, remove the covers on your floor, furniture and fixture then clean the area.
