How to Paint Birch Plywood
Lead Image for How to Paint Birch Plywood
  • 4-6 hours
  • 25-50
Damp cloth
120-grit, 220-grit, and 400-grit sandpaper
Rags
Denatured alcohol (ethyl alcohol that has been colored to indicate that it is not for human consumption)
Primer oil or alkyd-based
Paint roller - 3/8-inch or 1/2 -inch nap
Paint oil or alkyd-based
Damp cloth
Rags
Painting birch plywood is an easy process when you have the right tools on hand. All the tools that you need for this process can be purchased at your local hardware store.
Step 1 – Prepare the Birch Plywood
Using a damp cloth, wipe the birch plywood to raise the grain of the wood to make sanding easier. Sanding with the grain, lightly sand the wood with the 120-grit sandpaper, then do the same with the 220-grit sandpaper. Sanding helps the paint to adhere to the plywood. Clean the birch plywood with a rag that has been soaked in denatured alcohol.
Step 2 – Prime the Birch Plywood
Priming birch plywood is a necessary step to prevent acid or oils from leaching from the board. Using the paint roller, prime the plywood. Once the primer has dried, sand again using the 220-grit sandpaper then clean off the sanding residue with a rag that has been soaked in denatured alcohol. You may apply a second and third coat if you feel it is necessary, sanding in between each layer.
Step 3 – Paint the Birch Plywood
Apply the first coat of paint and allow to dry according to the manufacturer’s instructions. Once the first coat has dried, apply a second coat.
